What in the world are you guys talking about?
Alec you never drove your Sport on the street with no sway bars? Is this an IFS issue?
Am I missing something here? The only reason I even have sway bars is because I still tow a boat with my truck, otherwise they would be history.
I know MANY people who drive on the street with no sway bars, whats the big deal?
Lifted truck with no sway bars = drives just fine. Body roll is the only thing the sway bars prevent. Also with the sway bars hooked up the truck is MORE likely to lift a tire when cornering.
My rear sway bar is normally hooked up all the time, the front I only hook up if I will be driving a long distance or towing the boat.
I can adjust the body roll with the settings on my shocks.
OKay lets review my truck:
Springs, front and rear are about twice as soft as stock springs. Suspension has a 6" lift to it, so my center of gravity is higher from that and from 33" tires.
I also have tires that are much wider than stock, so that helps. Overall in the front my track width is 12" wider than stock. In the rear its 9" wider than stock.
the tires are 12.5 wide
I can adjust the stiffness of my shocks (so the spring rebiund rate) and when set on 9 (stiffest) the body roll is minimal at best. When set on 1 basically its like not having shocks.
My truck corners better than any stock BII WITHOUT sway bars and with the shocks set on 5 (half)
The TTB front suspension is horrible for cornering, because the camber change is so dramatic throughout the suspension cycle, much worse then the later IFS
With the sway bar connected the two beams have a semi solid lonk to each other, so when one goes up it wants to push the pther down. Without the sway bar it is a truly independant suspension, and I can tell you the truck is easier to turn and more responsive without the sway bar. IN fact with teh front sway bar hooked up the truck likes to lift the inside front tire on tighter corners.
I can say that with the rear sway bar hooked up the truck handles slightly better then without it, but it is easily manageable without it.
Maybe you guys should disco your sway bars and drive it around a little. Give yourself some time to get used to it and then see if you still feel it is "unsafe"
I can admit the first time I drove on the highway (for about 50 miles) from the trail back to town it was a little "different" and the truck likes to wander more in corners, but nothing you cant compensate for. Once you get used to it you dont even want sway bars again.....
