IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
Yeah I should have written this thread a year ago but I'm an insomniac tonight so might as well throw one up on ye ol' SAS registry.
Rear Axle
GM 14-bolt with Detroit Locker - 5.13 ratio converted to disc brakes
Front Axle
Jeep Grand Wagoneer Dana 44 with Aussie Locker - 5:13 ratio. Axle converted to run 8-lugs using Chevy outters for rear axle compatability.
Front suspension
3 link + panhard supported by 16" Fox 2.5 Air Shocks. Lower links made of 2"x2"x0.25" square tubing. Upper link made of 2"x0.1875" round tube. All links have rubber bushing on one end and RubiconExpress SuperFlex on the other.
Rear suspension
Stock leaves + AAL sprung-over axle
Steering (then)
Stock SOHC pump coupled to a Toyota IFS gear box with a flat pitman arm. SkyManufacturing Hi-Steer arms. All TRE's are the so called "Chevy 1-tons".
Steering (now)
GM Saginaw TC-style pump (from a Chevy Lumina) with bypass eliminated. Eaton-CharLynn orbitrol (aka steering valve). 2x8 hydraulic cylinder (limited with aluminum spacers). Prince Hydraulics RD-1800 adjustable relief valve.
Wheels
US Wheel 78 series - 15x10 2.5" backspacing
The crazy-delicious "dear God this thread is going nowhere" entiiire SAS thread:
http://www.explorerforum.com/forums/showthread.php?t=160724
