- June 16, 2003
- Humboldt, KS
- 2000 Mounty
A Zero will make it worse wont it. You need a 7 degree. Its free if you end up needing it. But mine are red.
The way I understand it the direction of correction with the wedges--more correction brings the pinion down further-or, twisting the axle rear ward.
Now if I was to install the wedges "upside down" it would rotate the axle forward 8 degrees from it's present position. The combination of the wild horse arm angle and radius bracket level will also move the pinion angle. For instance if the brackets hung lower it would create more caster and pinion angle
I'm going to try some 0 degree now, and may even try the 2 degree or 4 degree upside down.
