Ok adding the f150 leafs into the pack is just what this truck needed. Now the sliders sit level, the truck is level side to side, and, the ride is way better. I was expecting to get pounded, but it seems the weaker springs were just loosing control.
So, I took it for a dirt road test drive, and re toqued the new u bolts to 70 ft lbs. Then I headed for the higway and went to the pick and pull
Bad news-
I could not get techieman33's rear trim piece because the bolts were rusty and turned off --and I ate dirt trying
The Mounty is a 97 with non p internal egr engine. I was hoping to get a 98 version of the 4404 for Matts truck out of the deal-prefer to have the internal egr p heads, and therefore backed out of buying the package. I did secure a deal for the rear axle for rangrayy though.
Good news. I did get Danwhitaker's 97 hood latch, I scored the pair of leather power Mounty seats for 40 bux , and, I found a nice little relay box with relays for my lighting.
If anyone wants the mounty for it's drive train minus the axle let me know because This is a pretty good deal. Someone is calling for the heads and I got 3 days to give him an answer before they start hacking.
Truck has 170k miles. The yard will charge about 100 bux to pull the engine and trans for you--but you better get there first to save the wiring harness.
This was a rollover and has a good grill, and, the rear bumper with red lights in it looks to be saveable
but that is about it as far as exterior goes.
Edit
in looking thru the car I saw evidence of prior wheel stud snapping off, The broken ones are in the glove box with a reciept for repairs.
Looking at the passenger side front hub, I saw snapped bolts--and have to wonder if someone used cheap hubs at one point and this is what caused the rollover. Just an observation.
