just installed light bar!!!!!! | Ford Explorer Forums - Serious Explorations
I just installed my light bar this weekend, drilled through the roof in front of the sunroof and reinforced with 1/4" aluminum on the undernieth side, used a starter relay from a 78 ford, all together there is five kc daylighters right now until i get the money to go with the piaa's. will post picts within a day or two. I sandblasted the chrome and painted all the lights blue like the rest of my stuff. I'll have the picts up soon.
can't wait to see em :). i wish I had a sandblaster. Some day!
we have one here on base, $1 per hour its great.:D
well here it is:D
here is the side.
How much did it cost you to have all the underbody stuff painted?
I spent many an hour, many a wire wheels and paint strippers, and about fifteen cans of paint and around 10 cans of primer at around $3.99 each so not too much , just a pita to keep clean since I get muddy so much.:confused: :p
so what do you guys think???????
looks great!!How much did it run you and where did you get it?
actually I picked it up from a friend who had a toyota , $50 lights and the bar, the bar is a grizzly chrome tube and the lights are KC daylighters.
Are they the shockmounted KC's.They are very bright lights and suck up a lot of juice.I really like what youve done with your truck.Later Brad in Iowa
I had to make my own bushing/rubber spacers to go between the bar mounts and the roof. the lights have their own rubber mounts. also had to put some aluminum braces under the headliner to strengthen , they were wobbling pretty bad with out them. thanks
Looks great!
The color really makes it stand out. I like. :)
thanks Doc. It only gets better right!!!!!!!!getting my gears next week.:D :D :D :D :D :D
Looks great Mike. As bright as those daylighters are I think the extra mucho $ to go to PIAA is something I would put off for a long time.
Are the lights switched in pairs or all together? Is that what the heavy relay is for?
Later...
right now I have the outside and the middle one together and the other two on another. the relay helps my switches from melting down:D
looks very sharp! I agree unless you need to upgrade your lights for some reason, KC's are just fine and keeping them on there will save you the hassle of uninstalling/reinstalling :). Looks good though! Like it's made for the Explorer :)
mike, why is the middle light lower than the other 4?
It's just how the guy I got it from had it that way and I kind of like it so I think I will keep it that way,:confused: :D
sweet! I want to get a light bar!
