MythX
- January 3, 2012
- Colorado Springs, CO
- '04 Explorer EB
This truck has 135,000 miles on it, and appears to be in excellent condition. Of course, time will tell if there's anything hidden, but so far so good.
Is there anything specific I should examine on it? Common issues with this model that might not be obvious?
There's couple things I've noticed though.
1. When going from drive to park, it gets stopped halfway between park and neutral. If you're not paying attention, you could think it's in park and if you're not turning the engine off, you might get out thinking you're in park, but actually be in reverse. This doesn't happen all the time, but happens often enough I want to fix it.
2. When starting from a stop, the engine doesn't seem to rev up properly. If you're just giving it a little gas to creep forward, it doesn't respond, until you push the throttle past a certain point, then it surges.
Any thoughts?
Any thoughts?
