gungeek
- August 9, 2007
- Hagerstown, MD.
- 95 Ranger
....I know the Haynes books are essentially staeming piles of excrement, but that was the only source I had when doing the rebuild for torque, oil clearances, and Timing.
I set the gears dot up dot down like the book said to, now no start after install.
To be specific, crank gear dot is up, cam gear dot is down, used a staight edge and square to assure alignment.
The sensor that goes wher a distributor should rightfully be, had to be rotated and pushed down/picked up endlessly to reinstall on the cam spline and oil pump drive rod.
I kind of assumed that rotating the gizmo was ok since it probably only times spark in a loop with the thing on the front at the balancer determining #1.
While cranking now it wheezes and acts like any engine with a real distributor, installed wrong.
SO what did I screw up???
Thanks for any help.
Barry
Barry
