TeckNine4
- January 22, 2006
- Fort Myers,F.L./Fairfax,V.A
- '94 Explorer XLT 4x4
Well just got done putting in a 92' A4LD with 191,000 on it or maybe just 91,000 on it,
But the truck seemed as if it was more towards 191k instead....
(pix of swap soon) <Im sure no one cares though
It had painting on it from a Date last year 4-29-07, I noticed the Expo I pulled it from the trans was removed.
It has new seals in front and rear (it looked like by seeing it with the converter off)
I not sure if they did any new servos, band adjustments, trans-go kits, ECT,
I hope they did.:exp:
I paid 200 bones for it, Also i installed a much larger Trans Cooler then the factory aux cooler, (it seems to be shifting very smoothly and no leaks)
Iam wondering if I caught a good buy??
It has that common problem of not shifting into 2nd until its warm (who cares) I think its because of the new fluid and filter with o-rings...
It had the Traction-Loc (D4 code) axle in the doner truck and it seems overdrive has much lower rpm at 65mph than my previous blown trans. My gears are the 3.08s, (So I was thinking of swapping axles 2)
But the main reason and only problem I have is the Cable bracket for the kickdown cable I never hooked it up!! Does anyone have a picture of one hooked up so that I dont have to get wet and crawl underneath to switch gears?? It would be greatly apprieciated!
