CopenGrizz01
- October 26, 2015
- Indiana
- 2005 Murcury Mountaineer
I just bought a 2005 murcury mountaineer with the 4.6l v8. It has 139000 miles and runs and drives great. I love it. When I went to check it out and test drive it this knock was not present. After I bought it I drove it home which was about an hour drive. Parked it in the driveway and heard a knock. It only knocks at idle if I give it a little gas it goes away. It's not a rattle or tapping it's a knock. It does this all the time now. I'm afraid its a rod knock but wanted to ask you guys what you think. If your standing directly over the engine you can't really hear it but if you step back by the drivers door it's pretty loud. So I don't think it's coming from the top end. The engine is very clean no leaks at all it runs perfect not even a hicup. I can make a video of the noise if you all would like to hear it. I'm just really hoping it's not a rod knock. Oil pressure gauge is always right at half so I'm guessing oil pressure is fine unless the gauge dosnt work right. Also sometimes on a cold start the knock isn't there for about 30 seconds then in appears again and when it's somewhat warm out you can hear the knock up to about 1500 rpm and the knock increases with the rpm but then fades away. Thanks for any help.
