Chikar
- November 26, 2010
- Ladysmith, British Columbia
- 1999 Explorer Sport 4X4
Here's comes a probably dumb question.
I'm having a pre-ignition (knock) problem with a 99 Explorer Sport 4.0L OHV automatic on hills (and even gentle inclines if the weather is hot enough).
I've put a couple of cans of Sea-Foam in the gas tank over the past month or so which seemed to improve the situation a little.
But then I noticed the ping ONLY seemed to be coming from the passenger side! I had read somewhere this engine has two knock sensors, one on each side of the block, and I'm thinking the passenger side sensor might be bad.
But, all the on-line catalogs I've looked at show knock sensors only for the SOHC engine.
So, the dumb question...does the OHV valve actually have knock sensors and, if so, does anyone know where they are?
Thanks all.
Thanks all.
