Drewmcg
- August 27, 2015
- Location
- Michigan
- Ann Arbor, MI
- 2010 XLT 4WD
2002 XLS 2WD
You've left out some important info, so hard to advise. How many miles? Body in good shape? Any prior engine work done? And especially, any chain rattle on cold startup? Do you love your SUV?Question for you. For me as someone that is just getting into learning and repairing vehicles. How hard do you think valve covers on my explorer would be for a newby? I am comfortable do like breaks/starters and stuff like that but not 100% if i want to takle somthing like this by my self so early. I read around people say there a pain and they just took them to the shop to have them done . Some said it was not to bad. An input would be appreciated
Valve cover gaskets are not a trivial job for DIY on the 4.0 SOHC. It can be done with lots of research and patience (may take a couple of days all told). The big challenge is removing the plenum (plastic intake manifold). The star bolts holding down the plenum are real hard to get to, and could strip. Best to remove hood and use step stool to get the rear few bolts. Use 1/4 inch ratchet and variety of extensions, swivel joint. I even used a couple different profile star bits. And think trips to Ford dealer parts department for replacements, and waiting several days for new bolts.
Rock Auto for valve cover gaskets and new plenum gaskets. I've had better luck with the German ones than Felpro (which I generally prefer for other gaskets).
This work is far easier for a dealer or independent shop with experience on these engines (which have not been sold for 10 years).
Also, there are other things that can be best done with the plenum off, especially cleaning the throttle plate (seafoam good) and possibly replacing the fuel injectors (bosch rebuilt okay). But watch out for the seating gaskets for the injectors which sometimes need replacing (another dealer only part).
If you're crowding 150k miles, maybe new spark plugs wires (stay with Motorcraft).
If I didn't have several days of spare time, a good set of tools, and find joy in wrestling with the engine/plenum, and had a few hundred in the emergency fund, I'd have the dealer or a trusted independent shop do the work, and maybe have them clean the throttle plate while they're at it. Or live with the oil leak until you need to do the timing chain and all this stuff has to come of anyway. BTW, if you're smelling smoking oil, it's probably from the valve cover, not the main seal.
Main seal is a much bigger job, since it requires separating the trans from the engine.
