I`ve been to pirate and internet searched down anything to do with ant-wrap/trac bars. I finally have an idea for the anti-wrap bar, which will be only a little different than the samsoffroad one. (still iffy on going that route, or perhaps just re-building my spring pack, but my design pleases me)
I also gotta admit that I shouldn`t have bought bronco emergency brake cables without looking more into it. I can make it work, but I think it would be easier to just get a longer cable for the pass. side, which is too short.
The problem, which I`m not sure I mentioned, is that the 78/9 bronco has it`s brake cables running inside the frame, somewhere between the centerline and the frame to be exact. Bottom line is the pass side is way to short, and the driver`s side is just a smidgeon too long, but will work if I lengthen the other side.
I wanna work on the front a little more before I start messin` with the rear again, tho.
~Meanwhile, I do have the hydraulic lines to the rear brakes all installed~
I have my new clutch installed (+pressure plate and throwout bearing) The tranny is mounted in place again and suspended at the rear with a ratchet strap. Obviously I have to wait and see how the tranny will be mounted since it seems that the radius arm mounting point might interfere with the stock support.
- I trimmed some of the engine mount crossmember off and I am going to weld a plate on there to box it in, my research indicated it may hit my axle otherwise. I`ll get some pics up when I start on the plate welding.
I have some confusion on the front axle, it seems I can order c-wedge bushings in 2, 4, and 7 degree offsets, which can enable you to adjust your caster angle for lift, Thing is, I don`t know yet what the angle will be, since I don`t exactly know where the radius arms will sit verses the position the axle is going to be when it`s all together.
What I figure is the best option is to go ahead and install the axle with the old c-wedge bushings and decide from there. In the meantime, I have to get the axle and arms all cleaned up, and I want to replace any other bushings.
