ParkerRocker
- March 9, 2008
- Hayden, ID
- 92 Explorer Sport
I have recently replaced my fuel pressure regulator with a part from the local you pull it. I actually pulled three, just in case. I know that this one is working because i have vaccum tested the engine while using it and it responds predicably.
my problem is the seal, i am leaking gas from the point where it connects to the lower intake manifold.
I reused the O ring from the defective FPR, it leaked.
I reused the O ring from the "new" FPR, it leaked.
Inoticed that only ONE of the FOUR FPRs that i have in my posession have a rubber washer/band behind the O ring. Is this necessary to prevent the leaking? the old FPR did not leak and it did not have this on it.
As far as I can tell, its leaking from the point where it seals with the nipple on the FPR, that is to say the center of the O ring is not tight enough against the FPR to prevent 35+PSI of fuel from getting by.
Can i use a slightly smaller (but tighter) ring? Can I stack a smaller ring behind the bigger one to prevent leaks? Is there a trick to sealing this? I have used nothing, engine oil, and saliva to lube the ring before inserting the FPR.
