jturquette
- August 9, 2007
- Houston, TX
- 2003 XLT V8
I installed some LED bulbs in the rear brake/turn sockets on my X which caused the turn signals to flash fast. The computer was fooled into thinking there was a burned out bulb that needed replacement. I have noted in other threads that one fix was to install load resistors in parallel with the bulb to solve this problem. My concerns with this fix were:
1-the heat generated from these resistors
2-use of resistors negated the power savings for LED conversion
I found a replacement relay for the stock flasher relay that works well. I have yet to check that this new relay will not affect the cruise control (I doubt it will).
The flasher relay is located on the fuse panel, under the dash, above the drivers left foot. The fuse panel is two sided and the relay is on the top (the more difficult location to get at).
Here is a link to the ebay store that has the 5-pin relays:
http://stores.ebay.com/TMI-LED-TECH...-LEDs_W0QQcolZ2QQdirZ1QQfsubZ11QQftidZ2QQtZkm
I am also looking into some of their offerings for additional lighting.
My goal is to replace as many incand. bulbs as possible with LED and do an HID conversion of the low beams.
