nwag01
- August 14, 2008
- 1995 Explorer Sport
i'm at a dead end on this right now;
problem started when i turned the left blinker on a buzzing noise came from the flasher; right turn signal works, hazard works on the right side, wipers, etc. all work just not the left blinker
i read the post on this site about the mf turn signal switch and this is what i've done so far:
1st checked all the bulbs for damage -- all looked ok but i guess i should try replacing them anyway
2nd tested the relay under the hood on the driver side by swapping it with the righ turn signal one -- same problem with left blinker
3rd checked the turn signal fuse on the driver side in the fuse box -- looked ok
4th replaced the flasher -- buzzing noise stopped when i did that on the left turn signal but i still get no lights or indication on the dash; also the flasher in the cab and relay under the hood click on and off when i turn the left blinker on just no lights
5th replaced the mf switch on the steering column same result as the previous step
is there anything else i need to check on or double check what i've done so far?
thanks in advanced
thanks in advanced
