Lift kit interchangeability?? | Page 2 | Ford Explorer Forums
If the kits will in fact swap I have a couple other problems I'd like answered. The explorer does have the stock brake lines and the shocks they came with the 4 inch lift. Will adding these other 2 inches cause a problem with the brake lines now being to short? Are the shocks for the 4" and 6" the same length?
I would recommend getting extended brake lines up front even with the 4" lift, if you flex to much you'll rip the brake lines out. I'm surprised you made it thus far to be honest. I have skyjacker extended brake lines with 6" lift up front and am using stock brakes lines in the rear.
I'm using the 4" shocks from my Rough Country lift and have 6" suspension done to my truck, no problems. However, if you're doing SOA in the rear, you'll need stock shocks.
Where is the cheapest place to get some extended lines? Now I say their stock but hell I'm not sure. Do lift kits usually come with aftermarket brake lines? Do they make rubber extended lines? I just assumed they were stock cause they are rubber.
Thanks,
Gerald
Not sure about where you are but here the faster, cheapest and easiest way to get extended brake lines is to find a local hydraulics shop that will custom make them for you.
I did that for the rear, just took the stock one in and told them that I needed one like that but X inches long. 10 Minutes later he brings it out and it cost less than a OEM from from a local parts shop. This place even tested them to 3000 psi.
There have been a few threads/posts around here that talked about using f-250 brake lines for extended lines.. Its worth looking into..
~Mark
Ok let me finalize this right quick.
If I do a SOA i will need the stock explorer leaf springs and stock shocks? this along with the ranger 6" front will give me a total lift or 5.5"-6"? Correct?
What if I used the rearched explorer spings AND do a SOA i'm looking at 8"-9"?
Ok one other idea. If i do the one right above (rearched spings and SOA) Could I use the ranger 6" with some of those 2" coil spring lifts for a total of an 8" lift in the front and a 8"-9" in the rear? That sounds cool:)
Thanks for the help guys,
Gerald
Couple of things...
Any more than 6" of lift will also involve some tough issues with the steering, so REALLY consider if you need that much lift. Also, for any actual off-road work, having over 6" of lift probably means that you'll be the first one :roll: I'd cut metal before lifting that much.
Know that the steering upgrades you would need will cost over $1500... You MUST be able to steer that beast. Additionally, you will add much stress to the factory mounting points, which can cause a whole host of other problems. That really tall stuff is mostly a BIG headache.
One other issue with going tall -- you'll need tall tires to make it look right. They cost money -- double what a decent set of 33s or 35s would run. You then also run into the issue of re-gearing your axles to turn those tall tires. They won't run with stock gearing, so get out the checkbook... 2 axles will set you back around $1500 or more, depending on where you go. 3.73s (most common gear) will mostly only pull 31s, or 33s on the street. After that, you will only be turning 1000 rpm at highway speeds, which will lug your engine and kill performance.
Tall tires also tend to snap those axle shafts. They are -- at max -- rated for about 35s and at that, with a light throttle foot. Think SAS (dana 60s!) for larger.
You also need to be able to stop those big tires. Explorer brakes are pretty good, but they were not designed for really big tires. Expect issues...
About the brake lines -- any local hydraulic hose-building company can make new brake lines. I use Parker. They typically only cost $35 or so for a 24" line. Cheaper than aftermarket and better lines. They can go as high zoot as you like -- it is your money and they have the goods.
For the front lines, I use factory Superduty -- almost any year in the late 90s or early 2000s will work. They will give you line enough for 6" lift, or for 3" lift and a lot of flex (like 18"). You will probably need to capture them somehow -- I just used a long nylon tie and sort of held them in the vacinity of the coil spring so they wouldn't rub on the tires. Note that the lines may come off of the wheel calipers in a different direction than the stock lines. No big deal. They don't care... :D
I'm not trying to rain on your parade, but it is relatively easy and inexpensive to build a DECENT Explorer that will look good, run good, and give good performance to around 6" of lift, but after that, you need to be the son of an oil man to make the next step... :confused:
with a add a leaf should i keep the stock shackles on or put new longer ones on it?
Its up to you. If you want more lift than the Add-a-Leaf gives, then you can add longer shackles otherwise stock shackles work fine.
