The-Fox
- December 11, 2007
- Here, there and everywhere
- 1988 Ford Ranger XLT
I have looked all over the place and have not been able to find the caps for my 1988 XLT. If someone would be kind enough to help, I shall be greatly appreciative. I just need to know what the max rear bed payload is and the max towing load is. The specs are:
2.9L V-6 (got after market heads since the stock ones cracked so easily. The guy I bought this from was the auto teacher at my high school and he has an engine shop as a side business. He put larger valves and bigger injectors into it so he could move more motors at a time.)
Reg Cab/ long bed type 11 body
5 speed overdrive transition
F6 limited slip rear axle
4wd transfer case
Larger coolant reservoir
Just about every other option other then power windows/ locks
Thanks for any help and if you need more info, just ask.
4wd transfer case
