hillre51
- July 13, 2013
- vine grove, ky
- 2003 explorer eddie bauer
Hope all is well, I've a 2003 Ford Explorer, 4.0, 115K miles. Issue: Replaced Brake Pads on rear of vehicle and found that right rear is losing fluid BAD. Difficult to determine if coming from hose or caliper! Need to know the best way to find the leak! I'm assuming it's the brake hose vs caliper due to fluid was found on upper part of frame near coil spring and strut but was also found on lower control arm and upper section of tire. Didn't have any leaks prior to changing pads! Any ideas on what could have caused this? Over torqued caliper? damaged brake hose while changing pads? I have NEVER seen a system leak after installing the pads.
Thanks
Thanks
