Losing Fuel | Ford Explorer Forums
Losing Fuel
Cevigney
94 exploder
Pump is good, Pressure is good, Filter is clear.
Still the truck loses fuel from time to time. It will run for about 30 seconds then it just stops, If I can keep it at half trottle it won't stall.
94 XLT 4.0
I'm going to throw out some questions... I'm actually headed for bed but it will help others help you more quickly.
What measurement or symptom are you seeing that the truck looses fuel? You say pressure is good, do you mean it is generally good but sometimes it is bad?
Any check engine light?
What are actual pressures under what conditions?
Clean your IACV
Apparently the Sock fell off my Fuel pump causing every tiny bit of crap to get stuck in the screen. . Pulled all of that now she purrs like a kitten again, and for some odd reason my fuel gauge works again.
