dmaster79
- March 29, 2004
- Canton, OH
- '01 Explorer XLS 4x4
Here's the deal, on my '93 4wd Explorer, I was attempting to change the transfer case fluid. I went by what the hayes manual said and it was a mistake since they never mentioned being a drain plug as well as a fill plug I assumed they were the same like the front differential. After loosening the drain plug, fluid starting pouring out, as I figured this couldn't be right I tightened the plug up as quickly as I could, but lost probably 3/4 quart of fluid. After searching for a few minutes and taking loose the shift motor harness I find the fill plug of course and knew what I had done. After attempting to remove this plug for 2 hours with no progress, just the rounding of the recessed plug, I have given up for tonight. Since I can't remove this plug I cannot fill it. I need to know if its okay to drive this way for a few days until I can either drill it out or possibly weld somthing to it for more torque? I know it lost at least half of its fluid if not more, I will not be using the 4wd just standard 2wd. Can someone please tell me as soon as possible whether it is okay, since its my primary means of transportation right now!!...Thanks!!!
