bwryan
- August 22, 2022
- Centreville, VA
- 1994 Sport 4WD
Greetings all. I've searched the forum and still unclear on next steps. My '94 Explorer (5-speed, 190K miles) has been getting harder to start, worst when warmed up but also when cold, runs great once started. No codes, and KOEO and KOER tests reported no issues. Went ahead and replaced fuel pump relay and ECC relay, as well as various other inexpensive and easy to replace bits (crankshaft sensor, TPS, IAC valve). Finally got a pressure test kit, cycling ignition a dozen times it wouldn't get above 6 PSI then dropped back to zero. Once running, it held steady at 27 PSI. Anything else to check before bowing to the inevitable and dropping the tank? Thanks, Brian
