Benjam
- February 21, 2011
- WI
- 92 XLT Stick,4x4, 422 cam
Hi all,
I have a 92 explorer and swapped an M50D into it about a month ago to get rid of the A4LD. It has been working alright, and I have it wired so that I can start it but thats as far as it goes. I'm looking to get cruise control back, and reverse lights. I'd really like to make this factory, however, I have no idea what the factory wiring looks like with a manual in an explorer. The few first gen explorers in the junkyards around me are all autos, and the rangers are newer. I'm also not sure if the rangers use the same wiring?
Does anyone have a picture of the needed harnesses for the manual swap in a first gen?
I have a harness from a 94 Mazda B2200? with the stick shift, and the connectors are right for the transmission, and they plug into one of the harnesses up on the wheel well liner. But A:The Mazda harness is about 2 feet long. The old automatic harness from my truck is probably 4-5 feet long. And B: If I jump the reverse connector with the manual harness plugged into my truck, no lights. However if I jump the reverse pin on the auto harness plugged in, I get reverse lights.
To add to the confusion, I have an M50D from a 96 ranger. This means the top plate of the transmission is different than 94 and older versions. The older versions have 2 switches on the top plate, neutral sensing and reverse lamps. The 96 transmission I have only has the reverse lamp switch. I am looking to swap to the older top plate at some point, but in the mean time I want my cruise control back!
I know I can rig up the reverse lights through the old automatic harness, that is not my goal here.. The goal is to get cruise working, and make everything factory.
So swapping the harnesses around I need: To start the truck by pressing the clutch, reverse lights, cruise control.
I have service information from work and have been pouring through the pages but am not having any luck making sense of it. The diagrams for these older trucks are iffy at best versus what I am used to working with.
So after that short story, does anyone have any suggestions? Anyone been in my boat before?
Benjam
Benjam
