2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
Intercooler pump protection
I did some research on the Bosch intercooler pump before purchasing it. There were some reviews indicating early failure. I found that in the Jaguar and other luxury vehicle installations the pump was surrounded by insulation material to reduce vibration and noise transmitting to the passenger compartment. The insulation trapped the heat which reduced the life of the pump. I installed mine (with no insulation) under the air filter enclosure where there was access to ambient air.
I was surprised to read that the Varimax 410110 uses pulse width modulation (PWM) control. The cooling fins are probably to cool the power MOSFETs more than the pump. I suspect the Stewart-EMP pump is also PWM controlled and can be reprogrammed for higher flow probably at the expense of a shorter life. The PWM pumps probably have a programmable max duty cycle and have no means of monitoring coolant flow or pressure differential.
John, thanks for posting about the magnetic "clutch" in the Ford racing pump. I suspect it is identical to my Bosch pump. The clutch prevents the pump from overheating when there is too much restriction (differential pressure) in the cooling system. Lingenfelter's flow comparison chart indicates flow vs differential pressure.
I may try to measure the differential pressure of my system.
