3800 M90 Build | Page 40 | Ford Explorer - Ford Ranger Forums - Serious Explorations
3800 M90 Build
Ok the cats out the bag!!im going supercharged .its a 3800 gm m90.i need lots of help as im a nos guy.for starters my list of mods is in my signature.the guy im buying it from ran it on a stock tuned motor at 3psi.first question is what is the "safe" limit to run boost at?i know it is not ideal but i have a wide band O2 and will be doing tuning very soon.i also will be trying to have my company make a new lower intake mounting bracket on the cnc machine and have it taped for nos/water meth injectors/spray bars.i will also be getting a p+p unit from 3800 performance and stepping down on the pulley to try and run 8-10psi.what size injectors should i run for that?which fuel pump should i run?any suggestions on tuning?i was going to go mega squirt but i see sct has a new chip out,any suggestions?
DONE
ported and polished gm 3800 gen 2 m90
Water to air intercooled
port matched 76mm inlet and intake tube
mustang 75mm race tb
90mm maf
36lb injectors
255 fuel pump
sct 5bank dyno tuned
2.7" pulley 10lbs of boost!!;)
dyno run,these was the last two pulls with the 2.7 and the alternator was bad.turn your volume down!!
and a 3.25 pull and think my rev is still set to 5000 in this one
jd4242
va beach
92explorer&94 ranger
couldve had me come out. :rolleyes::D our rangers wouldve looked like christmas racing down the road hahaha
Hahahah
I was textn you wile doing have of them:D
jd4242
va beach
bovine
Fort White FL
1994 ford explorer 4x4
Well the plan for now is to cut the hood.then I can see how big of a cowl ill need.I have a 3" body lift in the explorer and its tight.but I also have solid mounts that raised the motor up about 2".from the looks of the ranger I won't need mounts that raise it, I'm actually going to try and build a set that lowers the motor some.but hell I think having some of the supercharger sticking out the hood my look cool and probably help cool it some, just can't drive in rain or the belt will slip;)
Yea the supercharger sticking through the hood would look cool you should try putting a 8-71 weiland like http://www.dyersblowers.com/1694.html and if you have one of those you need one of these http://www.alsblowers.com/streetcatcher.html :thumbsup:
jd4242
va beach
jd4242
va beach
So what does that mean?what needs to be done?i bought this pump and kit.does it have everything i need
http://www.redlinemotive.com/part-number/walbro/gss307-400-812.asp
Just a little update about this because I'm looking for one for my ranger now and I'm not going to reuse this one.they make a couple different 255 that fit, the walbro one you wanna use is the gss 340.I bought the gss 307:(basically the same pump but one performs wayyy better.this go around I think I'm going with the TRE 255.its gotten really good reviews and now with everyone making fake walbros you really don't know if it real or not.at least with the TRE you know its real.
Good read
http://www.racetronix.com/307vs340.html
kentpatton87
Mason, Ohio
'91 Ford Ranger XLT
Hey JD4242... I was trying to shoot you a PM but it says your inbox is too full
jd4242
va beach
Yea I know.havent got around to renew my elite. Alot of those messages are very important. .you can email me if you want..jhd421981@gmail
