Map light replacement. | Ford Explorer Forums - Serious Explorations
Gary Hines
Virginia Beach, VA
'98 Explorer Sport
Changing a burnt out bulb for one of the map lights. Twisted the old bulb to remove but part of the foil wire was stuck to the bulb and I tore it. Can this be replaced or must i replace the entire map light assembly. Part #?
thanks,
gary
Welcome to this forum! I've moved your thread into the stock 95-01 section. It sounds like you need a new socket or an assembly. Contact one of the vendors on this site. I'm sure that you might be able to get a new or used part.
