MyTruckNow
- September 29, 2013
- 2001 ford Explorer Sport
Autozone gave me 4 trouble codes, A week ago it was 2 codes one saying the "ECM has detected a rich or lean air fuel ratio on engine bank two."
The other one says.
"The computer has detected a rich or lean air fuel ratio on engine bank 1."
The truck only starts rough, and idles rough. When driving there is absolutely no sputtering nothing. When I start it up it starts rough. But the weird thing is if i turn the key to the on position, than shutoff the key Than turn it back on and start it. It starts up GREAT.
This is leading me to believe it is a fuel pressure problem? Because correct me if iam wrong but that starts the fuel pump up twice?
I have read on here ( been trolling this forum since i bought the truck a month ago.) that if u unplug the mass air flow sensor and run it if it runs better than it is the mass air flow sensor?
When a maf sensor is bad will it run rough all the time? like when ur driving? this only has a problem when u start it up and when it idles.
The other one says.
