Firstly I have already done a search but couldnt find a good answer. What is the largest tire I can fit on a 15x8 in rim. Any help would be appreciated. Thanks.
Approved tire width on a 8-inch rim is 12-inches, meaning any tire shop will install and maintain. Wider tires may require a specality shop for maintenence. Almoste everybody on this site runs 12.5 on 8-inch rim. Running a wider tire tend to cause tread wear problems.
The width you can safely run on a rim is dependent upon the height of the tire you want to run. It is all about the angle where the tire meets the wheel ( \___/ ), not the actual width of the tire.
