trozei123
- March 1, 2015
- 1992 Explorer XLT 4x4
i can't believe how much i have learned working on my ex. with 243k on the clock, im suprised that its still running after my neglect. my leak was cleared up due to there being 10 qts of engine oil in there (i am dead serious on that). my transmission is no longer sucking up fluid after i replaced the vacuum modulator. i got my idle fixed by adjusting the screw and cleaning and greasing up the throttle area. i would say, i am about 75% done with having a smooth running ex. just a spark plug change, and one thing with the trans and ill be happy.
here are my minor qs.
1. one thing that kind of bugs me and my fiance crazy is the fact that the knob that you pull to turn on the headlights is not illuminated at night. i don't mind it so much, but i noticed in the manual that aparently, there is a "headlamp switch bulb". is this true? can it be replaced easily? or does the knob simply not illuminate at all?
2. this would be the big project for me. i really am not sure if it is worth doing, but i have considered changing out the transmission fluid. as long as i have owned it, it has not been done. when i do drop the pan, i would put in a drain bolt to make it easier for the next time. i figure that i should start getting more routine maitenance done if i want the ex to last. after reading all about people not changing out the fluid if it hasn't been done, i am hesitant on doing so. would it benefit the trans if it has fresh fluid in it? or should i leave it alone?
3. my fiance and i both agree on one problem when driving the ex. the seats are not comfortable at all. i tried stuffing some old tshirts between the cover and the foam to make it better, but it made them feel worse. is there any way to try to make the seats feel better? or should i try to find new ones?
4. something i have noticed that has made me wonder is the steering wheel. it definitely has some play to it before it actually moves the wheels. also, it seems like the leather is always "oozing" out something. im not sure what to do about the ooze. would a front end alignment fix the play issue?
thanks to everyone that gave me advice before, and to those that will keep on giving advice.
