masospaghetti
- October 22, 2006
- Huntington Beach, CA
- 98 XLT, OHV, 4D, 4x4, 5M
I won't be able to post the tear down step by step (since it's already torn down), but here is the reassembly.
I had a lot of carbon buildup on each piston. I tried ATF, seafoam, and Berrymans B12 carb cleaner. The ATF and seafoam didn't do anything. The B12 softened the deposits so they easily could be scraped off with a nylon brush within about 8 hours. I bought 4 cans of it and poured enough in to each cylinder that it covered the entire piston. Obviously you will need to change your oil since a bunch of it will end up in the pan.
You will need to clean the head gasket surface really well. I used a razor blade and a bunch of the green scotchbrite. It took about 4 hours to do and sore hands, but you can't use anything too aggressive. There were some bits left that I didn't remove - I used the fingernail test (if you can feel it with your fingernail, it needs to come off).
The lifters go in first before the heads. They can only go in one way. Make sure they go in the same place they were taken from.
I installed the head without the manifold installed, but I would have installed the manifold ahead of time if I did it again on the driver's side. The access is tight to do it afterward. Install the head gasket (it's directional, make sure RH/LH is correct), then dropped the head on. Once the head is placed on the locating pins, thread in your head bolts a few threads and tighten by hand.
Per the FSM:
Position the cylinder head and gasket and install the new bolts in three steps.
Step 1: Tighten to 30-35 Nm (22-26 ft. lbs.)
Step 2: Tighten to 70-75 Nm (52-56 ft. lbs.)
Step 3: Tighten an additional 90 degrees
Drop the pushrods in next, again in the same place they came out from:
And next, the rocker arm shaft:
Position the rocker arm shaft and install the bolts in two steps.
Step 1: Tighten to 32 Nm (24 ft. lbs..)
Step 2: Tighten an additional 90 degrees.
Note: Even though it says to "tighten an additional 90 degrees", I don't think these are TTY bolts that have to be replaced. I may be wrong on this. I re-used mine.
Now do the same for the other head.
Per the FSM:
