fast_dave
- June 6, 2005
- East Bay - Nor Cal / PRK
- '98 Spt 4.0 OHV 5 spd 4x4
masospaghetti
Wait a full week of driving, and then add coolant to actually watch your pour-in and get the true idea of how much has been lost to get back to your reference line. It gives you a better idea than watching for a day or two.
BTW - What side were those last three plugs off of?
In my opinion, when clicking on the pictures you attached so as to make them larger, those last three plugs external electrodes and ceramic centers look like they're covered with the ash that forms when coolant is burned. Exactly like what forms on top of the passenger side exhaust manifold when coolant drips off of the heater valve.
You're truck will continue to run with a micro-cracked head.
It really only rears it's head and is noticed during the morning cold start.
Once warm, the engine runs fine the rest of the day.
BUT - you need to keep an eye on the coolant level and make sure it never goes dry. And as you have just written, after watching the coolant level since Friday (two days ago), you lose only a small amount of coolant.
The amount of coolant enters the combustion chamber on a daily basis is very small, and not enough to slip past the rings and contaminate the oil. It enters the combustion chamber and gets "steamed" instantly when the cylinder fires.
Your Ex is using coolant - OK - BUT try and see how much over a full week/full tank of gas it's using.That will then account into your "new" maintenance schedule - (i.e add a half-pint a week).
Bottom line on an Ex w/ 252,000 Miles; As long as your tailpipe isn't blowing white (steam) smoke after warm-up, and you're passing smog, I'd live with it, and just up your maintenance schedule - plugs every 15,000 and oil/filter every 3,000 miles.
