Beneastman
- August 10, 2013
- 2013 explorer XLT
Moon roof stuck open - shade is too - 2013 Expl XLT
I have a 2013 explorer xlt. 42k odometer. Power moon roof / sunroof. I retracted the shade all the way back, retracted (slid back) the sunroof and drove for awhile. Later I closed the shade and it stopped at the halfway point, as is normal. Then tried to close (slide forward) the sunroof (glass) using the center switch but the glass would not shut. I also tried to close the shade the rest of the way, since the shade switch usually also closes the glass, then shade in a single step. The glass and the shade are stuck in the open retracted position. Strangely I can still operate the shade from the back position to the halfway point. I can move it back and forth but only to halfway point. Neither the center switch or the left switch will close he glass. So I'm stuck with an open roof. I also checked fuse #8 and it seems ok. Thats the fuse for the sunroof according to the owners manual)
One other detail. I unclogged the driver side skylight drain 4 days previously, as the drain channel was holding some water. I cleared it but not sure how long water sat in channel. It did get wet at the headliner near the switches. However the whole sunroof assembly worked fine for a few days after that.
Wait one more detail - probably totally unrelated. On same trip had big difficulty pairing phone with sync prior to sunroof problem. I unsuccessfully tried to re-pair, even did a master reset of MFS. That fixed the phone sync issue. Again probably totally unrelated but stranger things have happened.
( I have an appointment with Carmax - I have an extended warranty - they may send me to dealer - but thats another subject )
Any thoughts or advice, similar experience or solutions?
Thanks!
Thanks!
