Ric94
- September 3, 2000
- Middletown NY
- 94 Explorer
94 EX
Doing front axle Ujoints one side no problem, the other side the 2 bolts that hold the anti lock break sensor are rusted to the point where the 6 mm 12 point socket doesn't work.
The other bolt an 8mm 6 point is also rusted but I think I can get that out by cutting a slot and using a screwdriver hopefully. Problem with the 6mm bolt is that its inset and no way get dremel in there to cut slot.
also what can I use to replace the clamps on the rubber boot thats on the two piece shaft?
Any and all help is appreciated
