J_C
- July 30, 2009
- Florence, KY
- 1998 XLT 4WD 4.0L SOHC
Got in my '98 the other day, and the windshield washer didn't work. I had a suspicion it was the steering column multi-function switch, not sure why, it just felt funny last time I switched from low to high beams and back. Granted I so seldom use high beams, it could just be that.
Anyway I suspected the multi-function lever, pried the end cap off of it, sprayed some solvent into it, and unscrewed the screw in the end of it behind that cap, which revealed nothing and seemed a dead end so I screwed it in again. The windshield washer didn't immediately work but I had other things to do and let it sit for a day.
Come back today and the windshield washer works again, but there are now no detents (notches when you turn it) like there used to be, switching from timed wiper interval to low or high wiper rate.
It works fine but eerily smooth, no feedback what position it's in.
Is there a trick to putting it back together a certain way if the screw was taken out? It seems odd that the front washer was the issue but now it works but the wiper detent is gone.
