Aaron 4.6
- August 6, 2002
- Augusta, GA
- 1998 Cobra
Actually, some of us do have aluminum blocks in our Mustangs....
No reason to limit yourself to the 03 Cobra crank. You can get used steel cranks from www.stangparts.com for about $150. The only problem with the buildup you suggest is that the 03 Eaton blower and intake will not match the 2V heads sitting on top of the Explorer motor. You will need to perform a complete 4V conversion, and at that point it would be cheaper and easier to install a complete 99/01 DOHC motor from Bishop engine and use a centi blower instead. Save money and make a lot more than 400 rwhp. Or even better, get VT engine to punch an aluminum 4.6 block out to about 324 c.i. and make that kind of power N/A. Of course you'll need a new fuel system to support that much power. I feel that there's actually a lot of parts available now for the 4.6 motor, its just that they aren't nearly as affordable as 5.0 parts, yet.
The Mustang intake wouldn't slow the Explorer down in a race. The truck intakes are tuned to make low-end torque, but the only time you get to use any of that low-end torque is off the starting line in 1st gear. Beyond that you will always be in the mid-to-top end of the RPMs, and you need more air to make more power there. You have an excellent point when it comes to towing, however. At highway engine speeds you could lose 10-20 lb-ft (I don't really know, that's just a guess) and you'd notice that loss pretty easy.
I wouldn't put a Mustang intake on an X as I would think it would make it slower. The X intake is designed to make torque which you need to pull a boat, climb a hill, etc. Plus an X weighs more.
