id fuse each of the amps sepretly and put the amp fuese close to the amp, ive been doing this recenlty and it works fine, cause if you think abou tit the only time its gonna blow is with a short, the olny time it will probibly short is installing or removing or if the amp melts(happened once) but the fuse is right there so its easier to take out when your working on the amp, but if your running 3 amps i would also have circut breaker at the battery as well, if one amp surges with only a fuse at the battery, the other 2 amps are going to get that surge as well unless there is a fuse inbetween the amps.
as far as wiring ive always split the battery wire equally, eg, 4ga-2 8ga, 2ga- 2 4ga ect. but check to see what you amps require, if they all require 4ga then id run 0ga to the dis block.
