cgriffin_5139
- October 11, 2005
Well I read all the posts concerning sway bar quick disconnects here's mine.
Quick Sway Bar Discos for Rear 2nd Gen Explorers
Parts List under $5
edit
1. 2 7/16’’ x 2 1/2’’ ajustable clevis pins
2. 2 pull pins (same size as the hole in the clevis pin)
3. 8 7/16’’ washers
4 1/2'' washers
Unbolt the links from the sway bar and frame. You will notice the bottom bolt is pressed in. The top has a nut which has a frame clip, take it off. Flip the link over and bolt it in to the frame using the existing hardware. This will be a little of a pain and you need a washer for a spacer being that the bolt is bit to long. After bolt in up the bottom hole should match up as before. Now take your clevis pin, slip on a washer slide it through both the link and the sway bar. Use two or three more washers for spacing and put in the pin. There your done!
Parts List under $5
edit
3. 8 7/16’’ washers
4 1/2'' washers
