My '94 extended cab | Page 7 | Ford Explorer Forums
My '94 extended cab
got some cleaner. one of the posts was dirty, but the filament was cleanexcept for one small dark spot. got the post cleaned off and couldnt get the one spot off tho. STILL having issues. so either its not the maf and its the ecm, or the maf is just faulty(ill try the expoloders), or theresa wiring problem
13.8mpg-14.5mpg 235/65r16 & 3.08 & 17 tooth speedo gear
15.13mpg with 235/65R16 & 3.73 & 17 tooth speedo gear
^(17.19mpg before gps corrections, truck thought i was going farther then i really was)
15.85mpg with 235/65R16 & 3.73 & 19 tooth speedo gear
^(prob more like 15.75mpg, as the speedo is just barely higher. got better due to im no longer turning higher rpm anymore)
so far thats a nice improvement, 1mpg-1.5mpg. i know theres more in there though. im still having issues when warm. im thinking it could be the ECT.
cleaned my old kkm filter and put it in for the hell of it. needed a new filter anyway
my injector cleaning project. this was my bad one. hardly any fluid came out when i first started. now all 6 drip this much. wish i had a way to pressurize it, kinda want to see it go 'psssssssssssssshhh' haha
when it all goes back together, hopefully itll run real nice now
http://www.youtube.com/watch?v=vdLe1gd5slY
Was these outa your ranger or the ex?
:JP:
exploder. the flow matched set on ebay. my rangers i tried cleaning a bit and they barely drip anything out at all.
Wow those arnt that old.not good.stick it in your mouth and blow real hard.....it will go pssssssshhhhh all over the place!!! Bahahahahahha:bsnicker::bsnicker:
had to take it apart AGAIN and replace o-rings cause it was spraying fuel all over. :(
all good now. but my old ones mustve been really dirty. cause not only does it run better, but now i get some horrible axle wrap if i launch it. i couldnt do that before haha
got some 33s. whos that peakin in the background? hmmm haha
new home for the old wheels and tires
then i flipped the rear back to soa with the exploder leafs. so the back should be 3.5" higher then the front, i forgot to measure.
and i was unlucky enough to get 2" exhaust, so that all came out in one piece lol
threw on the 2.25" pipe with the cherrybomb glass pack. its not to bad, deep tone to it. spray painted it to more closely match the rangers paint color.
Hahaha I look like a NINJA!!!:shifty_ey:shifty_ey:sawzall:
You didn't show the pic with the bed back on or where your old rims went to:D
yep. i love the way it looks like so far. i hope i dont need to trim the front bumper. i dont want to loose the rolled edges.
Naww your clear for what your going use it for
all done. just need tabs welded to the 8.8 so i have rear shocks, get it aligned, and have the sway bar end links extended 4".
its fully settled, i just think the alignment is screwing up the measurements.
drivers front: 36.75"
pass front: 37.25"
both rears: 35.5"
rear bumper: 21.5"
Haven't seen you around the forums in a while Xeek
Anything new?
Benjam :D
