ok,i just bought this,its technically a 92 frame,with a 97 body on it,i just trailered it home sunday.
i havent had much time to go over it,but the few things i do know...it needs a better front axle. the entire drivetrains from a 67/68 bronco
d30 front/9inch rear/302 and c4 trans with a dana20 i beleive tcase,its a cast iron case,very very closely resembles a NP205.
it needs ALOT of work,but i got a pretty good deal on it,i paid 700 for it as you see in the pics.
it also needs new springs all around,mainly,the front leaves are 6 inch {rear} ranger lift leafs.and they sagged quite a bit under the weight of the 302,and the rear is SOA conversion with i beleive 4 inch lift leafs,and 4 inch blocks,id prefer to just get taller front and rear leaves to level the truck out,and to get rid of the rear blocks.
heres some pics i took sunday night when we got it off the trailer..
currently it has qr78 buckshots on it,equivalent to a 36 inch tire...the previous owners had 39.5s on it efore they bought the new front leafs,i guess thats when they realized they screwed up and got too small of a lift spring.
the 302 runs,i gotta get the carb rebuilt and the damn starter changed,which requires at the minimum dissasembly of the pass side header/collector to get enough room to get the starter out.
i know it needs quite a bit of attention,but i dont think i did to bad for 700 bucks.
