- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Sounds like you need to remove the wheels, hubs, and rotors and plan on re=packing and or replacing the wheel bearings and race.
Also inspect th ehubs
Re-torque the wheel bearings
and check everything out
Also you can tell if your t case is in 4x4 by jacking both front tires off th eground, then spinning the driveshaft, with an open diff only one wheel will turn, if locked both will.
Then you can check your hub function in this same manner
If th efront d shaft wont spiin its likely because your t case is in 4x4 and the rear tires are on the ground.
With both hubs unlocked and th et case in 2wd the front d shaft should not spin while driving
if you have two bad hubs or a locker , it will spin even with the t case in 2wd
