- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
unbolt Dana 28
bolt in dana 35
get the radius arms with it, springs, sway bar, etc.
Make sure its got the right gear ratio in it before you put it back in 4x4
I think you can use your drivesahft for now, but if you ever go to a later model 1354 t case you will need that D35 front d shaft, your D28 one wont work. So its a good time to pick that up too.
You will have to bleed the brakes but the lines are the same
Good time for new wheel bearings, hus, diff seals, ball joints and tie rod ends
bolt in dana 35
