Hotweels
- May 7, 2001
- Calgary,AB
- '92 EB
well my 2yr SFA and C5 project is comin to an end
(visa LOVES me)
finnaly got my C5 from the wreckers last week and after a brief inspection i decided it look's pretty decent in it's current state so out with the blow A4LD and in goes the C5..... or so i thought.... nothing is simple.... easy yes!... simple?....NO
problem #1
when i removed the A4LD i compaired the 2 flex plates and the C5 flex plate has the starter teeth about 1/8" farther away from the starter
SO i am gunna see if the A4LD starter will catch the whole tooth on the C5 flex plate
problem #2
the explorer kick down cable fit's very nice on the C5 but the bracket to hold the cable is WRONG in so many way's
SO i get to build a custom bracket for the cable
problem #3
the factory colum shifter wont work and dont even get me started with the factory C5 floor shifter...... 4 linkages and it bolts to the block and frame... no... just no
SO i get a shiney B&M megashifter and this puppy bolt's up perfectly
problem #4
stock explorer tranny lines are 3/8" and stock C5 lines are 5/16"
SO i get to hunt down an adapter to join my 5/16" to the 3/8"
problem #5
the spot in the tranny hump where the new B&M goes is made out of tin and one good hard shift and i will rip out the mounting bolt's
SO i get to put a 3/16" aluminum plate under it to stiffen it up
problem #6
the drivers side exhaust Y-pipe wont clear the bump in the bellhousing for the starter
SO you either need to hammer the Y-pipe to clear the bellhousing or put the torque converter on the front of the tranny and try to line it up with the flex plate
this is just what i ran into today in no order at all.... will post some pic's when i get er all done
(visa LOVES me)
problem #1
problem #2
problem #3
problem #4
problem #5
problem #6
