Mat R
- February 9, 1999
- Woodinville(and all of western)
- '85
Tuesday, I woke up, got ready, and drove to work. On the way, my truck was making some funny noises.. kinda of a squeaking. I figured, time to replace the brakes again, and I finally was going to be able to justify those nice slotted rotors to help slow my 33s. I got to work, called NAPA placed the order, everything was cool.
I left work at 3 to go to school(University of Washington) and my truck was making the sounds again...except much worse. I switched to the slow lane, turned the radio off, making sure to note any "really bad" sounds. Of course that was when I heard something clank around followed by the scent of smoke. I'm thinking great, my pads are gone. So I decide to exit and see whats going on.
As I exit, I start to brake. I lose a lot of brake pressure, and as I near the light, a loud clunking comes from the front passenger wheel. More clunks, very loud. At a speed of 10-15 mph my wheel sperates from the vehicle which rolls into a ditch on the side of the road. The Explorer skids along about 15 feet. The vehicle stopped, and I thought "this is a very bad day"
To make a long story short. I got towed to Les Schwab(the ones around here are pretty good) they tell me that the bearings in my 4 month old hub seized up due to lack of grease which broke the spindle. They tell me to refer to the person that installed them.
That leads me to Eastside Truck Center. They "warranty" their work. The owner goes and looks at the hub, calls me back and says that it's not his fault. He explains that fords have a very small seal protecting the bearings and supposedly you are supposed to take your wheels off EVERY time you are done fourbying to check that they are dry and clean. He more or less states that there is dirt in the hub and that it is my negligence, not his. Basically he gets out of it because I have big tires, and there is no way I can argue. I saw the hub. Yes there was dirt, but very little, and it seems to me that if the bearing was properly greased it would of held up longer than 4 months. You also would think he would have told me about this bearing problem in the first place... not that it is his responsibility, but still....
Anyway, it's time for a new spindle, hub, brake line(which is extended), caliper, rotor, pads, bearings, and seal. A thousand dollars later, and I'm going to get my truck back.
A Dana44 looks better every day.
Did I mention the body damage? Looks like I'm going to be able to "afford" those fiberglass fenders a lot sooner than I thought.
Guys, be careful about you bearings, don't get screwed like I did...
Mat Sad
Mat Sad
