Need Help Installing Clear Corners on a '94 | Ford Explorer Forums
Bucktown
Southern CA
'94 XLT
Does anybody have any tips on how to install clear corners on a '94? I can't figure out how to get behind the stock lamps to unbolt them. How do I get in there? Thanks.
If I remember correctly, you have to remove the entire grill to remove the headlamp assemblies.
Good luck,
Rob O
'98 EB 4.0 SOHC 4x4
Twisted w/leafs
Edelbrock IAS
WAAG Brush Guard w/FET Landmaster 190 Hi\Lo's
Thule rack & bike trays / Yakima RocketBox
265/75/16 BFG A/T KOs coming soon
'94 XLT 4x4
WAAG * FET * 30x9.5 BFG * Doetsch Tech * Thule * Hella * Kenwood
I just replaced my main headlamp the other week, and it wasn't too bad. First you have to take out the top 3 screws under the hood. After you do that, just simply ease the assemembly out. Don't pull too hard, you don't want to break the wire connections. All you need to do is get a flat head and pry the clip of the side by using the corner of the clip. The bottom one is a little more difficult to get to, but it is the same thing. The corners should just slide right out after you have that peice off. I might suggest that you get someone else to pry off the clips b/c you need to keep some pressure on the healdlamp as you take them off.
Good Luck,
Chris
'91 Explorer 2dr
