explorerman3
- August 29, 2007
- gurnee, illinois
- 1991 ford explorer eddie
I need some advice on putting my front diff back in place. I just rebuilt the diff with all new bearings/seals/races and installed a set of 5:13gears and a Detroit truetrac LSD. After I bolted the front pumpkin up to the beam, I went to go slide in the driverside axle. It fits in there just fine (a little snug actually) until I go to put the spindle on. The axle seems to bind up somewhere inside the spindle when the spindle is all tightened up. The axle still rotates when I turn the pinion gear but I think it's rubbing somewhere inside the spindle. This causes a problem when I go to install the lockouts because the axle is not in the center of the spindle. There is no "wiggle" room like there should be, the axle is really tight. The spindle and axle are both the same units that I pulled out and they fit just fine before I pulled it apart. The pass side has no issues with fitment. Has anyone ever experienced this before when reinstalling their from diffs? Should I have waited to tighten up the diff bolts and diff bracket til after I fitted the axles in place? Please help! I'm VERY FRUSTRATED!
