Need Help With A Big Project... | Ford Explorer Forums
kvue1989
MN
2002 Explorer Limited V8
Hello All,
I really really need some help and info i'm new to the fourm and new to Ford just bought a 02 Explorer Limited and need to do a Super Big project to get this baby running again. I dont want to do anything yet need more info. Please help me and guild me to the right directions. Let me know what I should do first.
Thank You!
Parts That I Have With Me:
1. 4X4 Control Module 1L2Z-7E453-A
2. Bearing & Seals Hub Assembly - 2 Front & 2 Rear
3. Calipers - 2 Front & 2 Rear
4. Brake Rotors - 2 Front & 2 Rear
5. Brake Pads - 4 Front & 4 Rear
6. Sway Bar Link Kits - Stabilizer Bar Control Link Kits Front - 2
7. Tie Rod Ends - Left Outer
8. Belts - Poly Rib Blet - Alternator Drive Blet
9. Brake Fluid Exchange
Any guild info about the parts I have will help me alot step by step is even better thanks...
Just a quick look over your list there, it looks like probably everyone of these have an entire thread already dedicated to the particular project. Use the search at the top right and you should be able to find everything you're looking for and more.
I will try and do that thanks...
.... Let me know what I should do first. ....
I'm a firm believer that you should make it stop, before you make it go.
I'd go after the brakes first. ;)
Art :)
4x4 control mod
Big Rondo has a great how to for the 4x4 pcm. Its located behind the glove box. plug and play deal there.
How do I find Big Rondo so I can look at his How To...
Go under the search function, go to advanced search, and search by user, and put the key words "4x4" and "PCM" in as well. That will show you any threads with posts he made with those words in them
Big Rondo has great writeups, and is very helpful to everyone. You have a question, he has an answer.
Quick question...
Front wheel bearing & hub what is the torque specs for the 3 bolts that holds the front unit together.
Rear wheel bearing & hub what is the torque specs for the 3 bolts that holds the rear unit together.
Quick question...
Bearing and hub are pressed in, no bolts to torque
1. How much torque need it for the front.
2. How much torque need it for the rear.
1) Manjina gave you the torque spec fo rthe three front bolts for the hub and bearing assembly its 83 ft/lbs.
2). THE REAR BEARINGS ARE NOT HELD IN WITH BOLTS THEY ARE PRESSED INTO THE KNUCKLE> THERE IS NOTHING ON TH EHUB TO TORQUE.
Thanks lol now I know...
Please Help Need Some Torque Info:
1. Both Front Sway Bar - How Much
2. Front Axle Nut - How Much
3. Rear Axle Nut - How Much
Until the bushings begin to bulge. If you overtighten them, you risk crushing the bushing or pulling it through.
