lobo411
- September 14, 2011
- 1996 Explorer 4.0 OHV
If you now have 182,000 miles on your original OE ball joints and the boots have been torn for a while I pretty sure they're worn out. I bet if you get around to changing them you'll be amazed at how worn they really are.
Maybe whether the Motorcraft price is worth it or not depends on use. If I expected to put another 100k on the truck in the next 5-7 years, I'd probably go aftermarket. I only put about 2000 miles on it, though, so I'd probably shell out for the Motorcraft parts because I'd think of them as "lifetime."
Ya, my original ball joints are most likely worn, but it's hard to say how badly. It still handles fine, and I don't have any clunking or popping sounds while steering or going over speed bumps or anything. I do have squeaking when I go over speed bumps, but the squeaking happens when the front wheels clear the bump and then it happens again when the rear wheels clear the bump. I read a thread somewhere that suggested that the squeaks are caused by worn torsion bar Kevlar pads, which can't be serviced.
