hrasnake
- June 7, 2018
- Honaker, VA
- 2000 Ford Explorer xlt
I have a 2000 X xlt 4x4 with the 4.0 OHV that I purchased from my grandmother. It had been parked for a year, she needed the money and I needed a 4x4. 114k miles on it and needed a water pump and a tune-up, simple enough. Has run great for me until the past 2 weeks. CEL came on and absolutely no power going up hills and idle drops drastically when it is in gear and the DPFE was melted. I have researched the forums extensively but have not been able to fix the issue. Seems to idle fine but this thing is crawling up hills. Doesn't seem to be running hot.
The vehicle has gotten these new parts in the last 6 months.
I borrowed an OBD-II reader today and these are the codes I am getting.
- Fuel Filter (Motorcraft)
- Water Pump (Delco)
- Plugs (Motorcraft)
- Wires (Denso)
- Coil Pack (Motorcraft)
- IAC (Delphi)
- DPFE and new hoses (O'Reilly house brand)
- Upper Intake Manifold gasket (Fel-Pro)
- Air Filter
- P0352 Ignition Coil B Primary/Secondary Circuit Malfunction (new coil pack. Doesn't make sense)
- P0303 Misfire Detected in #3 Cylinder
- P0304 Misfire Detected in #4 Cylinder
- P0306 Misfire Detected in #6 Cylinder
- P0113 Intake Air Temperature Circuit High Input (changed the IAC this morning so likely an old code)
- P0102 Mass or Volume Air Flow Circuit Low Input
- P0122 Throttle/Pedal Position Sensor/Switch "A" Circuit Low Input
- P1504 Intake Air Control Circuit Malfunction (again replaced this morning)
