Need Tire Sizing Help! | Ford Explorer Forums
eX mobile
Roswell, Georgia
2002 Explorer Sport
Hello, first off I am running the basic 2" suspension lift off of tt/shackles. I was wondering what tires I should choose. I would get 31x10.5 but personal preference I think that the tires look a bit small in that wheel well. Any way possible to run 33x12.5 on this 2" lifted wheel well? Will it rub? If it does rub what do I need to trim to get rid of the rub? If it helps to know, I drive a 2002 Explorer Sport. Pictures are more than appreciated.
Matt
http://www.explorerforum.com/forums/showthread.php?t=67200
95-2001 (including 2dr 95 - present)
No lift- 31x10.50x15 on 15x8 rim or stock (15x7) rim
1-2 inch suspension lift - 32x11.50x15 on 15x8 rim/ may require some extensive fender trimming
4 inch suspension – 33x12.50x15 on 15x8 rim
2 inch body lift – 32x11.50x15 on 15x8 rim
3 inch body lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 4 inch suspension lift - 33x12.50x15 – 35x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 1-2 inch suspension lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 4 inch suspension lift – 33x12.50x15 – 35.12.50x15 on 15x8 rim/ may require fender trimming.
You may be able to run 33x10.50x15s inplace of 32x11.50x15s
I know that chart, i meant what is needed to be trimmed on the fender.
