New Aerostar with 59K miles! | Page 3 | Ford Explorer Forums
On my ex it is missing a blade and all cracked at orielly it was 30. With lifetime warranty
I got Exs at oreally at that time I thought it was really bad it just had the small stress cracks nothing like the huge gorges my aero has
I did a lot of searching but can't find an original design fan blade for the 3.0L engine. There's lots of them available for the 4.0L but 77% of the Aerostars came with the 3.0L engine - go figure. Anyway, I found a couple on Amazon for under $27 + shipping. Both of these claim to fit a 1996 Aerostar XLT 3.0L
Have a look:
Flex-a-lite 1018 Dark Blue Star Aluminum Blade 18" Low Profile Belt Fan
Flex-a-lite 418 Black Nylon 18 3/8" Belt Driven Fan
If you pad the order over $35, the shipping is free.
Best of luck.
This is working link to the "Parts Geek" from Post #45 . You have to scroll all the way to the bottom past all the blades listed for the 4.0L engines to find the fan blade for a 3.0L. $43.35 for Hayden Part Number: 4944-07027008
Notes: Engine Cooling Fan Blade -- Flex Fan For Standard Rotation Standard Duty Thermal Fan Clutch; w/ AC. Vehicle • 1996 Ford Aerostar Engine 3.0L V6
1996 Ford Aerostar Fan Blade @ The Parts Geek
(Remove all the spaces in the link below to use it)
http:// www. parts geek. com/ catalog/ 1996/ ford/ aerostar/ cooling_system/ fan_blade.html
It might be cheaper to buy one from Amazon and pay for the shipping.
(It sure doesn't like The Parts Geek without the spaces)
I tried searching at Rock Auto - they have fan clutches but no fan blades listed.
iv been looking and looking to for fans I was at junk yard by my house and there about 4 other yards close to me I still need to check but the one down the road has about 15 aeros and I cant get the nut lose for the single bolt fan clutch there are in really nice shape well a lot nicer then the one I have I was able to get the head light conversion parts for less then 25 bucks with the sealed beams to .
does that big metal fan bolt up to the stock fan clutch the fan for the 4.0 looks like it would bolt up
Here's a trick that will help you get the fan off very quickly. Connect a Vise Grip onto the lip of the water pump pulley, and let it press against the bracket. Get a fan clutch wrench, box wrench or an adjustable wrench, and put a pipe over it. You could even use a piece of PVC pipe if you don't have an iron pipe. Remember that the thread is left handed when you apply pressure to unscrew it. You should be able to break it loose instantly, then turn it by hand to remove it.
ok ill give that a try my next run to the yard still on the hunt for center caps and beauty rims
iv been to two different yards and cant find a good fan blade or any thing for the rims
My favorite yard hasn't gotten an Aerostar in for sometime and they crushed a few they had. I suppose with the last ones rolling off the line 16 years ago, the supply is drying up.
I think that the supply decreased severely with the cash for clunkers program.
I have at least 25 Aerostars between the three yard by me theres more yards a bit out but not to far of a drive im not driving that far out for a fan
The 1996 Aerostar Made finely made it to 60,000
I've been following along on another post that's saying you should be prepared to see it start over at 300,000 miles after it goes past 399,999. :D
