StryctNy9e
- March 10, 2011
- Beaverton OR/ hayward CA
- 1993 XLT Exploder
1993 ford explorer XLT 4x4 atomatic. I did a engine swap the last two days.
Engine went in smooth and I took it out for the first test drive last night and the truck didnt want to go over 25 mph. I didnt get a exact rpm reading I just know it wasent right because I could hear the engine reving and no reaction. I tryed to punch it a couple times to get some pick up but nothing. My main concern is if somthing is wrong with the torque converter. Just to let you know I have done several engine swaps hondas (manuals) and my chevy (automatic). So I have been around the block but this is my first ford swap.I dont know a whole lot about these trannys so it is holding me back.
My main concern is if the torque converter is not on all the way or if a sensor is jacked, or if I messed up a tranny pump without realizing it. Or whatever advise you want to give that would be of help.
First off I made sure I seated the torque converter all the way on the tranny shaft. I have done it before but I made sure to consult my chiltons to make sure. Is there a specific place the flat spots on the torque converter shaft should have been when I put it on( horizontal or vertical)? I made sure to check the fluid levle and its good. A friend said it could be a air bubble in there if so how can I check or get it out? How can I tell if I damaged the pump or if the pump is working?
I hope I didnt damage the pump. I dont mind pulling the tranny to fix the problem I just want to get it fixed. It really sucks that I got the engine in and want to test it out and I cant because I f**ked up somewhere along the line. PLEASE HELP any advise is appreciated.
